Disconnects and noise on line
No, but the engineer said the fault shouldn't be closed off as the armoured cable is faulty 16 meters from the inspection hatch and needs replacing before all 4 wires fail.
He was to recommend this as he suspects the tree roots are compressing the cable.
Hi fr8ys
If the fault is no longer present (fault symptoms) then the engineer may not carry out any further work.
If you do experience any further issues then please let us know and we can escalate this back over to Openreach.
This widget could not be displayed.
