Downstream: Actual Rate vs. Maximum Rate
1 REPLY 1
Hi Forum,
Please see table below.
 Actual            Maximum
DownstreamUpstream
299997161
385087161
Is there any chance my Actual Downstrem Rate could (can) increase?
I seem to be capped at a flat 30mb. I've monitored this for approx. 1 week, and the results are always the same.
TalkTalk Wifi Hub (version SG4K10002600t) is connected to Main Socket, and via an ethernet cable.
Thank you in advance.
If the actual is the 30M line, what was the guaranteed minimum you were originally quoted, or how far away from your fibre cabinet do you live?
Assuming 30M is the best you can get, then to get the higher figure you would have to pay for the fibre speed boost from MyAccount. Only you can judge if the extra amount is worth it for less than 10M faster.
