Draytek Vigor 130 will not connect
3 REPLIES 3
jetty19
Hi - I have a Vigor 130 modem which is to be used in conjunction with our Unifi security gateway pro.
I've tried for hours to get the thing to work - it is refusing to connect to talktalk. I have followed the guide on DrayTek's website (https://www.draytek.co.uk/support/guides/kb-isp-talktalk#vigor-vdsl2-modems) but still refuses to connect.
Any suggestions ? Does talktalk block mac addresses belonging to third party modems still ?
jmclevine
TalkTalk don't block the use of third-party routers or modems. However, they don't use the same authentication as BT and others who use PPoE authenticiation. TalkTalk use DHCP/IP authentication so requires different settings. I have read various posts about it being able to connect to the TalkTalk network but it being a bit more tricky. I can't access the links you require a login but this link may help:
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
“The journey home, is never too far...”
jetty19
Finally figured it out - I'm on a business account which must be different to the standard account.
Everyone has said use dhcp, refused to connect.
Followed the draytek guide, then connected using PPPoE. Needed a username password which talktalk doesn't use on the standard modem/router. You need to call 08700875562 from the fibre landline to find out your login credentials.
Hopefully this helps someone else with a similar issue.
Hi jetty19
