Dropping connection after three engineer visits
84 REPLIES 84
alexpacini
I have a problem since a couple of months: my fibre broadband drops continuously.
I had three engineer visits (with other three no show... but I have been told there was a problem with the OpenReach booking system) but the connection still drops.
Each time the engineer reset the DLM, the connection goes back to 40/10 but then it is reduced after some drops (it was 3.8/0.8 before today's visit).
Some days the line is not even able to connect, which means no internet at all.
The problem is that the test performed by the engineer presented a good line, with a reasonable attenuation and very few errors.
I don't really know how to proceed, it was ok for the first couple of months and then this problem started. Is it worth trying replacing the modem/router?
Thanks, Alex
Alex
OCE_Debbie
Hi Alex
The line tests haven't detected any faults but I can see re connections.
Just to confirm, which router are you using? (make and model)
alexpacini
TT Sagecom Wifi-Hub FAST5364-3.T8
FW: SG4K10002600t
Alex
OCE_Michelle
Hi alexpacini,
Ok thanks for confirming this. Would you like us to send a different make and model of router for testing purposes to see how the stability compares?
alexpacini
Hi Michelle,
well, yes, thanks.
What should I do with the router then?
Alex
OCE_Debbie
Hi alexpacini
I can send another Wifi Hub or I can send a DSL3782 or HG633 router. Which would you prefer to test with?
alexpacini
The Wifi Hub would be fine I think.
What should I do with the current one?
Alex
OCE_Debbie
Hi alexpacini
The replacement Wifi Hub is on its way and a returns bag for your old router. You should receive this within the next 24-48hrs.
alexpacini
Thanks,
I hope this will fix the issue.
Alex
OCE_Debbie
Hi alexpacini
Please let us know if you are still experiencing any further issues with this router.
alexpacini
Actually, I hope to be at home when it will be delivered.
It is possible to add an alternative delivery address (my workplace)?
On a side note, I was expecting a reply (in 72 hours, which ended a couple of hours ago) from your Network Team, but I have not received anything. Do you know anything more about that?
Alex
alexpacini
I called the customer service and the fault has been escalated to the "Manchester team" which should call me back on Monday evening.
Alex
OCE_Michelle
I'm sorry for the delay. Thanks for the update and please let us know how you get on.
alexpacini
I received the replacement router, but the connection is still dropping.
I was expecting a call today from 6 to 8 pm from your "Manchester team", but no one called.
Disappointing.
Alex
OCE_Michelle
Hi alexpacini,
I'm sorry to hear this. I've re-run the line test which is detecting a fault towards the property. Could you confirm if the master socket has a test socket and if you're also using the new cables and microfilter that came with the new router?
As soon as we have confirmed this then we can escalate this straight over for investigation.
alexpacini
The last engineer replaced the socket and the microfilter is not required anymore.
Anyway I tried the test socket before and the problem persisted.
I am using the new cables.
Alex
OCE_Michelle
Hi alexpacini,
Thanks for confirming this. I've asked our Network Team to take a look at this now. If you don't hear back by the end of today then please can you bump your thread and we can re-check for an update for you.
alexpacini
Thank you. I will.
Alex
alexpacini
unfortunately I haven't received any communication yet.
And the connection is completely broken this evening.
I am basically paying for a service that was not usable for two months.
Alex
