Every evening my speeds drop to around 3mbps compared to around 34mbps in the daytime. I don’t understand why there is such a drastic drop. It’s very frustrating as the evening is when it is used the most.
Hi @Turneri90,
The staff here will be able to take a look at this for you, but they won't be back here until next week, and will have a backlog of posts from over Christmas to work through, so they will hopefully be able to respond sometime next week to help.
Hi Turneri90
Apologies for the delay.
Please can you add your TalkTalk landline number to your Community Profile, we can then look into this further.
Hi thanks for getting back to me. I do not have a landline number sorry.
Hi @Turneri90,
If you have regular Fibre then you will have a landline number, even if you don't use a landline phone, you can see the number on screen if you log into 'My Account', it may also be visible on screen if you go to the Service Centre
The staff here won't try to call you on the landline, they just need the number to be able to identify your account.
All tests are clear and all levels across the line also look fine.
When the speed drops, are you using wifi or a direct wired connection ?
Do you know if anyone else is using the connection at the time and if they are using anything that may utilise bandwidth ?
If you can also run a wired ping and trace route to google when the speed is low, that will help.
Hi Turneri90,
How has it been since your last post. Have you had chance to run the ping and traceroute yet?
That's great news Turneri90, thanks for letting us know
my connection has dropped off again, it dropped to around 3mbps at one point I've attached a ping and traceroute word document. I've been getting speeds of 65mbps and up for about 2 weeks and now its gone again.
Hi Turneri90,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault and the sync speed looks consistent. Just to confirm, is the speed slow at all times of the day or just the evening? Please can you run a wired speed test using the TalkTalk Speed Tester so we can see your recent speeds.
in the day its generally good. i get speeds around 65 to 75 mbps but most evenings it drops significantly. I've attached and print screen of a speed test this evening.
just to add this was a wired test with no other devices connected.
Hi Turneri90,
Thank you. Can you run a few more speed tests during evening and also during the day as well so our Network Engineers can see the change in speeds and we can log this straight over for you.
I've attached a few speed tests the higher speeds are during the day and the lower speeds are from around 6pm until 12pm.
Hi Turneri90,
Thanks for the information. How has it been since your last post, have speeds still been dropping in the evening?
Thanks for confirming. I've passed this over to our Network Team for investigation and I will post back here as soon as I receive an update back.
