FTTP trial
1 REPLY 1
merrybobs
I have just received an invite to join the trial in Culcheth but my info was rejected because I had not included my postcode. There is no box on the form for a post code !!!
OCE_Michelle
Hi merrybobs,
I'm sorry to hear this. Have you a look at the below as the first step is to input your postcode? You just need to click register now and follow the steps. Did you receive a letter from freedom fibre? If so there should be an email on the letter that you can contact for support.
http://talktalk.co.uk/culcheth
