Fast 5364-3. T8 Router VPN issues
38 REPLIES 38
PJH1968
I am having an issue with connecting to my works remote desktop via VPN. When attempting to connect it says "(Failed to get domain name) Could not download the configuration from the server".
My IT department has advised that it is something to do with TalkTalk's broadband / router configuration. My VPN works fine on other wifi networks and all other employees using the same setup have no issues. I am using Watchguard Mobile VPN with SSL.
I have already added my first & last name, broadband phone number & alternative contact number to my profile to enable TalkTalk tie up my forum username to the broadband account.
Its watchguard mobile vpn with ssl
Any advice would be greatly appreciated!
Divsec
Hi Phil, welcome to the community. Your router does support VPN so a couple of suggestions until the OCE team pick up your post and give you a good answer.
Did you try checking the Homesafe settings and disabling as many as you can?
Also worth changing the DNS servers from 79.79.79.79 and .78 to 8.8.8.8 and 8.8.4.4
Worth a try
D
Hi Philhulme,
Sorry, I can't see any details in your profile so can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
PJH1968
Hi Chris
Please try now, all added.
Phil
OK thanks, I'll take a look at this now. Did you try Divsec's suggestions?
PJH1968
I did not try Divsecs suggestions. It's for a works laptop I use at home so I referred it to our IT manager here. A colleague here had the same issue & didn't need to do it so we decided to leave it until such time as you had a chance to look and could hopefully update the firmware as did with my colleague.
Thanks for your prompt attention.
Phil
I can try another firmware version, is it OK to update your router firmware now?
PJH1968
I'm not at home so can't tell you anything but sure please go ahead do what you can & when I get home I can try.
Phil
OK, I'll try updating your firmware later this afternoon as I'm having problems communicating with your router at the moment
PJH1968
The landline telephone number I put in my profile I am 75% sure is right but I have been with talktalk for many years and never had a phone connected to the landline so I do have a bit of doubt. If required I can give further info but obviously via a secure platform
Phil
I can find your details but looks as though the router isn't connected to the internet, is it currently switched on and connected to the telephone socket?
PJH1968
I can confirm the router is on and connected to the socket
Phil
PJH1968
Just had the other half check and it appears there is no internet connection on the TV though. Netflix won't work & Amazon gives warning about low band width.
Phil
PJH1968
ok restarted TV and it Netflix works now. Amazon prime also now working.
Never had that issue with either before.
Phil
OK thanks, I'll try to update your firmware again, I'll let you know how I get on
OK, I've updated your firmware, it should complete in a few minutes. Could you please retest and let us know if there's any difference
PJH1968
Thank you Chris. I will retry this evening when return from work & let you know.
Phil
PJH1968
Hi Chris
Afraid it has not worked. Can connect but terrible lag.
Phil
OK thanks. I can send a different make and model of router to test with, would you like me to arrange this?
