Fast fiber keeps cutting out on tv and phones,
this has been happening for the past 2 days and as often as every 10 mins.
i will be watching Netflix and all of a sudden it will freeze, so I look over to the new home hub modem and instead of a solid light blue light it is flashing red and light blue. This will occur for up to 3 or 4 minutes before it will lock back on to the internet on resume my tv show.
I have tried leaving the hub off for periods of time but this doesn’t seem to help at all.
Is anyone else having these issues? Does anyone know what is causing it? Or when this might get resolved. Every now and then is one thing but every 10 mins is just a joke!!
Hi @Selina5 ,
The router flashing white and orange means it has lost its connection with the internet and is having to reconnect.
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
For one of the TalkTalk staff on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
The staff on this forum work normal office hours, so you may get faster support by using the live chat or phoning up over the weekend, however the staff on this forum should respond to this topic early next week to help if you are still having issues.
Hi Selina,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
