Faster Fibre 150 slowed down
41 REPLIES 41
Hi after a few issues l got faster Fibre 150 installed a few weeks ago .Speeds were fine for the first 2 weeks at 120. -130 Mbps however over the last week they have significantly dropped and range between 58 - 97 Mbps. Can someone at talk talk look into this please and advise.
Many thanks.
52 Mbps today Tuesday 8 Sept slower than what it was before installation.
Hi Nautilus186,
I'm sorry for the delay. I've run a test on the line which has detected a possible issue towards the property. Has the set up changed at all since the engineer set this up?
No the set up is the same.
If no changes have been made to the set up then we can arrange an engineer visit to the property. Would you like us to arrange this for you?
Yes please
Hi Nautilus186,
If you'd like us to arrange the engineer visit can you confirm:
I've also sent you a PM with some additional questions
Hello Chris
I assume that there is no charge if it is openreach or talktalk equipment that is faulty.
On that basis l accept. am would be preferred.
Hi Nautilus186,
No there would be no charge if it's faulty Openreach or TalkTalk equipment. Are you available for any AM appointment? Would you just like us to book the earliest available?
Earliest available would be great. Openreach only installed it 2 weeks ago.
Hi Nautilus,
I've booked the engineer visit for tomorrow AM (September 10 2020, 08:00-13:00) - please let us know how you get on
Sorry to be a pain Chris but something has cropped up at work is there any chance we could arrange it for Friday am instead?
Hi Nautilus186,
I'll take a look at it now, is Monday AM OK if Friday isn't available?
Hi Chris
Monday am would actually be better if it is easier for you.
It doesn't make any difference to me really it's whichever you'd prefer. Would you like me to go for Monday AM even if Friday AM is available?
Yes please Chris as it gives me chance to rearrange my work schedule. Thanks for your help.
No problem. I'll change the appointment and let you know when I've done it
OK, I've re-booked the engineer for 14/09/2020 08:00-13:00 - please let us know how you get on
Thanks again Chris
Hello Chris
Openreach have been and there were some issues from the previous install which have been rectified.
The engineer stated that there maybe a problem with the ethernet ports on my router as after install over wifi I am getting 140mbps but over Lan ethernet the talktalk download speed check link only states 52mbps. As they are 1gb ethernet ports I believe this should not be that case. Could the ethernet ports on the wifi hub be faulty in some way ?
