Faster Fibre Boost - Latency
16 REPLIES 16
Enlightened One
My Faster Fibre Speed Boost activated today with download speeds increasing from 39 to 70 Mbps and Upload from 9.5 to 18 Mbps.
Subsequent speed tests show Latency has increased from 9 to 16 ms.    Is this increase to be expected and is Latency likely to reduce to its original level over a 10 day period while things settle?  Thanks.
Hi aa2000
Its best to allow the 10 day settling in period to elapse.
Continue to monitor.
Enlightened One
Thanks. 6th of September diarised, shall report back then.
Enlightened One
Am pleased to report that as of this morning, speeds have further improved (Download:  73.7 Mbps  Upload: 18.6 Mbps) and since a few days ago, Latency has reduced to 8 ms.
Measured with Google Search Internet Speed Test.
Hi aa2000
Your line is showing in sync at 79mb.
Enlightened One
There seems to be a fault with your 'Service Status' facility in My Account.  Estimated Speeds have not taken the Fibre Speed Boost into account and this morning it is returning the following status:
Your broadband connection could be improved
Our health check on your service shows that your speed to your router could be improved.
Your Line Speed
Your Estimated Speeds: 39 Mb - 40 Mb. Your Actual Speed: 76 Mb.
Hi aa2000
Are you running this test when connected wired?
Enlightened One
Yes.
Hi aa2000
Please can you power down your router for a full 30 minutes and then run the test again?
Enlightened One
@OCE_Debbie wrote:
Hi aa2000
I powered down for minimum 30 minutes, tested again and the result hasn't changed:
The health check we carried out on your broadband line shows that recently you have not been receiving the estimated download speed we guaranteed when you signed up to TalkTalk.
Estimated speed: 39 Mb - 40 Mb
Recent speed: 76 Mb
I notice that community member @Col_J appears to have a similar issue in his post can a Oce_ check if DLM is active after speed boost was added please
aa2000
Hi aa2000
The sync speed looks good, line is in sync at 76.6mb
Can you run the speed test on a different device?
Enlightened One
Hi Debbie
I only have the one device (a laptop) available to me at the moment so am unable to test on another device.
I'm happy that my speeds are ok, so am not unduly concerned, other than it would appear (see my previous post) that your 'Service Status' may return erroneous results for some (all?) Fibre Speed Boost customers.
aa2000
Hi aa2000
If the throughput speeds are low (speed tests) based upon the sync speed then this is why you are receiving this message.
It would also be worth trying the test again in a different browser.
Enlightened One
Hi Debbie
I just completed the test using the Microsoft Edge browser and the result is exactly the same.
aa2000
Hi aa2000
Thanks for testing this.
It would also be worth testing with a different device.
Enlightened One
Hi Debbie
Good news, Service Status now seems to be working correctly. 🙂
See below for latest Speed Test results from 'My Account'.  Do those test results seem ok, or lower than you would expect?   Laptop is hard-wired to Router and is the only device running.
aa2000
Hi aa2000
That's great, thanks for keeping us updated 🙂
The speed test results look good based upon the sync speed.
