Faster Fibre only getting 13mbps
26 REPLIES 26
StimpUK
I went live nearly 2 weeks ago and have only had around 13mbps on speed tests since day 1 despite guaranteed a speed of 30-40mbps.
My router is connected directly to the master socket via a prefiltered socket I have tried connecting my laptop via ethernet with nothing else connected and still only get around 13mbps.
My parents who live round the corner, are on TalkTalk and get the guaranteed speed.
I have tried borrowing their router to see if mine had a problem but that didn't make a difference.
I have been on the live chat and had tests run but no faults have yet been found.
I would appreciate any suggestions on what to try next.
Divsec
Hi @StimpUK welcome to the community your post has been flagged for assistance and you should hear back on Monday. In the meantime try a 30 minute reboot. Power down and restart 30 minutes later. This can frequently resolve the issue.
StimpUK
Thank you
I have tried this but will try it again.
Look forward to hearing back on Monday.
StimpUK
I tried the 30 minute reboot again but it hasn't resolved the issue.
I tried carrying out a large download and noticed that the download speed would fluctuate wildly between around 1mbps to up to around 30mbps.
I should also point out that I bought a landline phone to test for interference on the line but didn't experience any crackling when using it to make a call.
Hi StimpUK,
I'm sorry for the delay. I've run a test on the line which hasn't detected a fault. Could you run another wired speed test with no other devices connected to the line please using the TalkTalk Speed Tester. Can you also run a wired ping and trace route and post the results into the thread.
Run a Ping or Traceroute
StimpUK
Thanks for getting back to me.
Please see below for test results:
Pinging google.co.uk [172.217.169.35] with 32 bytes of data:
Reply from 172.217.169.35: bytes=32 time=13ms TTL=56
Reply from 172.217.169.35: bytes=32 time=15ms TTL=56
Reply from 172.217.169.35: bytes=32 time=14ms TTL=56
Ping statistics for 172.217.169.35:
Minimum = 13ms, Maximum = 15ms, Average = 13ms
Tracing route to google.co.uk [172.217.169.35]
over a maximum of 30 hops:
1 <1 ms <1 ms 5 ms ttrouter [192.168.1.1]
2 * * * Request timed out.
3 13 ms 12 ms 16 ms ae50-ner001.thw.as13285.net [78.144.1.1]
4 13 ms 13 ms 13 ms ae50-scr101.thw.as13285.net [78.144.1.0]
5 14 ms 13 ms 14 ms 72.14.209.10
6 * * * Request timed out.
7 13 ms 13 ms 19 ms 172.253.65.208
8 13 ms 13 ms 14 ms 108.170.246.143
9 14 ms 14 ms 14 ms 216.239.58.3
10 14 ms 15 ms 14 ms 216.239.59.76
11 15 ms 15 ms 14 ms 74.125.242.97
12 15 ms 14 ms 14 ms 172.253.66.89
13 13 ms 14 ms 14 ms lhr48s08-in-f3.1e100.net [172.217.169.35]
Hi StimpUK
The pings and traces look ok. Is the throughput speed (speed test results) the same at different times of the day?
Your line is in sync at just under 40mb.
Please can you try another 30 minute power down of the router and then run a speed test? It may be worth arranging a TalkTalk engineer visit to complete further investigations if the speed doesn't increase.
StimpUK
Hi Debbie
Thanks for your quick reply.
Yes, I have tried speedtests at different times of day and on different devices and can't get it to go over 13mbps.
I have tried the 30 minute power down quite a few times too.
Yes, I think it might be time to call in the engineer 🙂
Hi Chris
I'm just sending you a Private Message to confirm some details so we can arrange a TalkTalk engineer visit.
Hi Chris,
I've replied to your PM
Hi Chris
Thanks for the PM. In answer to your question, the line profile can cap your sync speed but this isn't the cause of the issue here as your sync speed is 37Mbps. I can't see any reason why your throughput speeds should be so low and consitently around 13Mbps
Could you try another speed test with every device in your home that connects to the internet switch off accept the device that you're running the speed test on
StimpUK
Thanks, Chris
I will try that tonight.
Hi StimpUK,
How are you getting on?
StimpUK
Alas, no joy 😞
Can you check your landline and see if there is any interference/noise when making a call.
StimpUK
Thanks for the suggestion.
I bought a phone just to test this and there is no interference or crackling when making calls.
Hi StimpUK,
Thanks for trying that.
I've passed this back to our network team, if you don't hear anything later today can you bump the thread again tomorrow and we'll check for updates
Hi StimpUK,
Our network team have advised to arrange another TalkTalk engineer visit to check your setup as they can't see any reason for the slow throughput speed, if you'd like us to arrange this please let us know.
StimpUK
Hi Chris
Thanks but my setup is fine, if I was getting varying speeds I could understand that it may be my setup but I get the same speed every time I run a speedtest under optimal conditions (wired connection, no other devices connected). It has never gone over 13mbps.
Also, as the router performs perfectly when setup on someone elses line with the same cables (ethernet/power/RJ11) I can't see how my setup could possibly be the problem here.
So, thanks but I'll make do for now.
StimpUK
I did a bit of Googling and found someone with the same problem and it turned out to be a "misaligned virtual path profile" but apparently this information isn't available to first line support and he ended up having to email the CEO to get it fixed.
Could you maybe pass this up the chain for me? it would be nice to get this escalated rather than getting stuck in an infinite loop.
