Faster Fibre speed boost
7 REPLIES 7
Repeat Guest
Have just added faster fibre speed boost to my package on Saturday which should go live today was told it would probably take another 24 hours for this to work ?
Does it normally action automatically or would I need to switch off router for 30 mins for this to happen?
Jo B
They say "up to midnight" so wait until then if necessary before trying the 30 minute switch off. Keep us posted one way or the other.
Hi Joblake1966
Please can you add your TalkTalk landline number to your Community Profile, we can then look into this further.
Repeat Guest
There does seem to be a better signal now so hopefully that means the speed boost has taken effect.
thank you for all your help.
Jo B
Hi Joblake1966
What speed are you now receiving when running a speed test?
Repeat Guest
Hi Debbie, my measured speed is currently 45mb today which when I do a live test says my broadband is below what it should be and could be improved, think should be between 49mb and 78mb.
Thanks Jo
Jo B
Hi Joblake1966
I'm just sending you a Private Message to confirm some details so I can check the predicted speed range for your line.
Hi Joblake1966
Thanks for confirming your details.
The predicted speed range for your line is showing between 71 and 51.5mb, with a guaranteed minimum speed of 45.1mb.
Your line is now showing in sync at 55.9mb. What speed are you receiving today when running a speed test?
