Faster Fibre - terrible performance
UnclePunch
Still no dial tone.
Hi @UnclePunch
A fault has been detected so I will pass this to our network team.
Hi @UnclePunch
We have requested an engineer to go out to the exchange in the next 48 hours.
We can check the fault ticket on Friday for an update
UnclePunch
Problem appeared again tonight. Between 7pm and 10pm my down/up went as low as 3mbs each (lower at first). I reset the router which made no difference, since then I have plugged directly into my test socket to see if I notice anything. Is there an update from the engineer coming out last week?
Hi UnclePunch
I've requested an update from our Network Team and I will post back on this thread shortly.
Hi UnclePunch
The notes advise that the engineer did complete work at the cabinet.
I've completed a line test which is detecting a possible fault. Is the landline service working ok when making calls?
UnclePunch
I've managed to make a call for the first time, its not the best line but it worked. Since switching to the test socket I've also had better down/up speeds.
Hi UnclePunch
Is the line noisy?
Would it be possible to test with a corded handset at the test socket with the router removed from the line and check for noise?
UnclePunch
The line crackles and has reverb (even being able to hear yourself).
I don't have a corded handset, but tested the line directly and it sounds the same as with the router plugged in.
Hi UnclePunch
Do you have 2 separate cordless phones? (just so we can rule out any possible issues with the handset)
I can then raise this fault over to our Network Team for investigation.
UnclePunch
I do not unfortunately.
Hi UnclePunch
Would it be possible to test your phone on a different line? (family or friend)
UnclePunch
Tested the phone on a different line and it was all clear.
Hi UnclePunch
Thank you.
I've escalated this fault over to our Network Team and I will post back on this thread as soon as I receive further information.
Hi UnclePunch
Our Network Team have attempted to contact you to complete some further testing.
They have suggested arranging a TalkTalk engineer visit so further testing can be completed. Would you like me to arrange this visit?
UnclePunch
I would. Would this be weekday only?
Hi UnclePunch
We can also try and arrange a weekend visit
Hi UnclePunch,
Thanks for the PM
I've passed on your availability to our network team, we'll let you know when we receive confirmation that the visit has been booked
Hi UnclePunch,
Our network team have initially logged this out as a non-appointed task, we should receive an update within 48 hours so if you don't hear anything beforehand can you bump the thread on Thursday and we'll check for updates
UnclePunch
Any news?
