Faster fibre slow only 2mb
25 REPLIES 25
Been with talktalk for several years never had a problem. Till this last few months the speed as dropped off. My minimum speed guaranteed is 21mb only been getting 2mb. Tried the chat line twice
on for over an hour both times. They would not believe me when I said I never switch the router off. I did once for the 20 minute test made no difference. The second time had me checking connection which I did.
My service centre says
Your Usage
Line length limits your speed. It may become an issue if your usage of 177 Gb increases
Your Line Speed
Est. speed: 26 Mb - 40 Mb
Measured speed today: 2 Mb
alan73
Hi Alan
I've completed a line test which hasn't detected any faults and the line is in sync at 18mb
Is your router connected at the test socket? I can see some re connections on the line, is the connection dropping or has the router been rebooted?
I have only switch the router off once for 20 mins. I don't have a test socket that I can see on  t he box
Thanks for your reply
alan73
The connection dose not  dropped just stays slow
alan73
Hi alan,
Can I just confirm, does your master socket look like the below?
Your guide to main phone sockets
NTE 5
alan73
Hi alan,
Thanks for confirming. This socket should have a test socket below the lower part of the faceplate. Would it be possible to connect the microfilter and router at the test socket for 48hrs so we can see how the speed and connection stats compare?
Ok just done that thanks
alan73
Hi Alan
Thanks for doing that. Unfortunately there doesn't appear to have been any speed increase. How is your telephone service, can you hear any noise on the line?
no the phone is fine
alan73
I have had this problem for several months. Been with Talktalk since they took over aol and never had  any problems. There is no point in paying for faster fibre if I am no longer getting it. It needs someone coming out to fix it or talktalk cancelling the rest of my contract. So can get another internet supplier.I prefer to stay with Talktalk will move if i have too
alan73
Hi alan,
Thanks for confirming. Do you have an alternative router that you can test with? Have you recently tested with a different router at all?
I don't have another router the one I am using is from talktalk about 12 month old
thanks for replying
alan73
Hi alan,
Ok thanks for confirming, would you like us to send a replacement router for testing purposes to rule this out?
yes will try that
alan73
Hi Alan
Thanks for that will let you know if it is better
alan
alan73
Got the new router the speed as gone up from 2mb to 10 mb so a move in the right direction. Talktalk have found a fault on the line as well and are fixing it in the next couple of days
Thanks alan
alan73
Hi Alan
