I don't think I've ever had particularly fast speeds but just thought it was down to the deal I was on. Based on this I upgraded to Fibre 150 today but have since been poking around and found my current speed is well below guaranteed (~21Mb).
How will this effect the speed I get on the new deal? Is 20MB all I can expect from the current line? Also the go live date isn't until April, is this correct that I need an engineer visit to change to this deal?
Thanks,
Sam
What type of Faster 150, FTTC, or Future Fibre? Either way yes, an engineer visit is required to install a modem and a bit more in the case of full fibre.
OK, thanks for that. The only thing that puzzles me here is that product is only available to those who already have top of the range FTTC speeds available unlike the ones you mention. Wait and see what the support team have to say when they pick this up in the next day or two.
Hi Sam,
Line test is picking up a potential problem. Are you experiencing any problems with your telephone service, do you have a dial tone? Is there any noise on the line?
(I've also sent you a PM)
Hi Sam,
Line test is showing a fault so I've raised this as a non-appointed task to Openreach. Openreach will investigate over the next 72 hours and may contact you directly. If you don't hear anything before Tuesday please let us know and we'll check for updates
Hi sam,
I'm really sorry for the delay. Is your router currently switched off?
Hi sam022,
I can see that this has been logged out to Openreach again, if you don't hear anything beforehand can you bump the thread on Monday and we'll check for updates
