Faster fibre speed drops and rises same times every day
9 REPLIES 9
onslow
G'day
I would be grateful for any advice or assistance on this matter as I'm old and not the sharpest tool in the box  re technology.
I've been on Faster Fibre  for over a year  and all was fine with 25/30Mbps download speed until the last month or so around Xmas time.
Since then there has been significant drop in download speed at 'peak' usage times when the speed is woeful.
I have carried out regular speed checks over last 7 days (8/10 checks daily) with the following results
0630 - 0830 hrs ------- 6 to 9 Mbps ( Peak)
0830 - 1200 hrs -------- not checked
1200 -1900 hrs -------- 20 to 25 Mbps ( Off peak)
1900 - 2300 hrs -------- 3 to 10 Mbps  ( Peak)
2300 - 0630 hrs--------- not checked
Used both cable and wifi for checks with little difference between method. (HGG533 supplied for faster fibre by TT)
Download speeds alter without any rebooting or system alterations and happen every day at same time.
I supplied this info to TT Chat yesterday. They checked line and found nothing wrong recommending an engineer visit.
 I am now getting slower download speeds at peak times than I was receiving prior to changing to faster fibre.
As 20/25 Mbps is stable over a 7 hour midday period each day I suspect heavier line usage at 'peak' times for loss of speed.
What should my next step be. Is an engineer visit really necessary and would I be charged.
 Can the speed not be increased at the 'peak' times by Open Reach to fix the problem on the speed check evidence supplied.
I had difficult times with TT about ten years ago and don't want to go through similar times again. I'm too old for all that especially as my Virgin neighbours get stable much faster speeds and never stop telling me about it.
Grateful for advice
Onslow
DAVID MORRIS
onslow
Thank you for getting the ball rolling Keith.
Much obiged.
David
DAVID MORRIS
Hi onslow
Apologies for this.
I've completed a line test which hasn't detected any faults and your line is in sync at 40mb.
I can send a replacement router for testing, would you like me to arrange this?
onslow
Thanks Debbie.
Can you briefly explain what in sync at 40mb is.
Is it download speed of 40mbps?
Todays checks 0700 ---- 9mbps
                         1315 ---- 9mbps then 18mbps
I look forward to trying the replacement and hope it solves the problem.
Best regards
Onslow
DAVID MORRIS
Hi onslow
Your sync speed, also known as your access line speed, is the maximum speed at which your router can connect to the internet. Download sync speed is showing as 40mb.
Your speed tests shows throughput speed. Your sync speed will always be higher than your actual (throughput) broadband speed because it's completely free from signal interference.
The replacement router is on its way, please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
onslow
Thanks Debbie. Let you know.
Never to old to  learn I hope.
Onslow
DAVID MORRIS
onslow
G'day Debbie
New router installed and running at a much improved 30 + mbps but dropped to approx 14mpbs then rose again to 30+
Will run it a few days and speedcheck it before I get back in touch.
Hopefully it will improve speeds overall.
Thanks for your speedy response and quick supply of the router.
Onslow
DAVID MORRIS
Hi onslow,
Ok thanks for the update and please let us know how the speeds compare 🙂
