Faulty router
4 REPLIES 4
I’m frequently having to reboot or reset my router. The white light stays on showing a broadband connection, but no devices will connect. After the reboot, everything works fine for a few hours. I’ve spoken to support, who run tests but for some reason won’t just replace what is obviously a faulty router. This has been going on for three weeks. It’s driving me crazy. I have one of the new black routers.
If these devices are wireless ones, it is not necessarily the router (which one Sagemcom or Huawei) that is at fault here at all. Far more likely is WiFi interference. Do you have any wired (Ethernet) connected devices & if so how are they?
All devices lose connection including a TV and Apple TV which are connected directly to router.
Hi Roger1612
I can see you have one of the Huawei Hubs.  Can you configm if all devices drop the connection, even those connected to the router via an ethernet cable ?
Can you also check the home phone and tell me if the dial tone is clear, no crackling etc
