Fiber is dropping every 5-10 minutes
19 REPLIES 19
clarkead
Hello
I've had talktalk fiber for six months now and it has been excellent until yesterday.
Periods during the day it has been dropping and reconnecting which is getting very annoying because I can't figure out why, I've changed nothing and as far as I know no one else's fiber on my street is doing it, any suggestions pleases and before I get the reply yes I have turned it on and off again and taken wires out and put back in etc.
Hi clarkead,
I'm sorry to hear you're experiencing problems with your service.
Do the lights change on your router when the connections drops?
Are both devices connected to your router by wifi and ethernet cable affected by the drops?
clarkead
Yes whenever it happens the light goes from white to flashing orange back to white after a minute, it did this six times in the space of ten minutes last night. And all devices are connected over WiFi as the router is nowhere near anything for ethernet.
Hi clarkead
I've completed a line test which has detected a possible fault.
Is your landline service working ok when making calls? (any noise on the line)
Is the router currently connected at the test socket?
clarkead
Hello
Well I don't actually use the line for phone calls so I don't have a phone connected.
But I've just connected the line to the test socket and I'll see if that makes a difference.
Hi clarkead,
Thanks for confirming this. If the connection is still dropping now that the router is connected at the test socket then please let us know and we can look into this further for you.
clarkead
I've been keeping an eye on it all evening and sadly it's still dropping very frequently, will it be a problem with the router as the connection been perfect before this week? It's starting to effect my partners work as she uses Skype alot to talk to work. Thanks.
Hi clarkead
Apologies for this.
The line test is still detecting a possible fault. Would it be possible to borrow a phone just to check if your landline service is working ok?
If you are experiencing a fault with the landline service then this can affect the BB connection and has to be investigated first.
clarkead
Right I managed to get a phone to plug into my phoneline and I'm getting no dial tone at all from the phone and it's a brand new phone so it can't be that so what does that mean?
also I've spotted today that my download speed is very low, even with this problem it was at around 12-18mb and today its at 2mb.
Hi clarkead
Did you connect the phone at the test socket, with the router removed from the line? I can then pass this fault over to our Network Team for investigation.
clarkead
Hi, I've just tryed all that you said to do and I'm still getting no dial tone with the phone connected up 😕 thanks
OK, I'll drop you a pm so we can request an engineer for you.
clarkead
OK I've pm you all the info, thanks
Hi clarkead,
I've replied to your PM
clarkead
Just wondering as well would this problem affect my fiber speed? Because not getting fast speeds at the moment, should be getting 30-40 mb but am getting around 9-12 at the moment.
Hi clarkead,
I'm sorry for the delay. The line test has detected a potential fault so I've passed this to our Network Team now and I'll let you know as soon as I receive an update back.
clarkead
 heres a picture and it's dropped about 7-8 times in the past hour 😕 not very good 😞
An engineer has been booked for Mon2nd sept 1-6 PM.
This is the earliest appointment available.  If you need to reschedul for a later day, please let us know.
clarkead
OK thanks, I'll be in at that time 🙂
