Fibre 150 install
He did visit first yes, to change the bt socket and plug the modem in
So its all set up
Hi abntt7,
Thanks for confirming this. I've re-checked the connection stats and the line test is now detecting a possible fault towards the property and the sync speed has dropped. I can see that the line test was clear when we last checked this. I'm not sure if you have specifically changed the set up since then but if you have would it be possible to change it back so we can re-run the test again please?
Hmmm ok
No its back at the original setup / cables.
As soon as the new cable arrives tomorrow I'll connect it and reply to check then?
Hi abntt7,
Ok please let us know how you get on and we can re-run the line test again.
Ok new cable in
Speed test direct patched to modem now 102Mbps, so improved
Can you please run the line test again?
Tests are still failing and showing a possible bridgetap within the wiring close or within the premises.
Next option is to arrange an engineer, would you like to proceed with this ?
Thanks for checking.
Yes please, makes sense to do so.
Looking at the telephone cable coming to the house. It splits at the house , one end going to the master socket and the other to a socket in the bedroom (not used / previous owner)
OK, I'll send you a PM with some info to confirm.
OK thanks. I'll await that.
Is there anything I need to do to get the engineer booked in?
Did you reply to @OCE_Karl's PM, @abntt7 ?
Sometimes it takes a day or two at the start of the week to catch up with the backlog from the end of the week before as well as the weekend.
Hopefully an OCE will let you know asap.
Gliwmaeden2
Hi abntt7,
I'm sorry for the delay. Did you respond to OCE_Karl's Private Message?
No probs
No, not had a PM off anyone yet
Andy
Hi Andy
Apologies for this.
I will re send the Private Message to you now.
Hi Andy
Thanks for the Private Message.
The engineer visit has been arranged for Wednesday 05/08 PM (1pm - 6pm)
Got it now thanks
Replied.
ta
Hi Andy
Perfect, Thanks for sorting it out
Hi Andy
No problem 🙂
Update.
All sorted.
Openreach engineer identified and fixed the fault.
Some old extensions outside that split off before the master socket. (a bridge-tap or star wiring he said)
Speeds instantly > 130Mbps, so happy
Thanks for your help with this
Andy
