Fibre Broadband +Wifi Hub can not connect to VPN
1 REPLY 1
denman
I have just set up my fibre broadband but cannot connect to my work's VPN through Cisco Anytime connect.
Do I need a different router?
There are no known VPN issues with the hub, when you try & connect is the IP address that will be potentially offered to your PC via your IT people's VPN server, conflicting with the 192.168.1.0 network?
