Fibre Broadband speed issues
11 REPLIES 11
ilhan
I have very slow fibre braodband (includs boost) 6Mbps download and 13 upload! (my previous thread was deleted it seems) I have added my home number in settings too. Please help.
@OCE_Chris @OCE_Michelle
ilhan
Can somebody help please?
Hi ilhan,
I'm sorry for the delay. I've run a test on the line which hasn't detected a fault and the sync speed looks ok. Are you connected wired or wireless?
ilhan
I use a wireless connection.
ilhan
Can this urgently be looked into as todays speeds are (much) slower.
Hi ilhan
Your line is showing in sync at 79.7mb.
Have you tested different wireless channels to see how the speed compares? Change your wireless channel
Please can you also try powering down your router for a full 30 minutes and then run a speed test following this?
ilhan
I've tested it again today - I've got 46.7 for d/l and 18.2 u/l.
The routers only about two metres from the computer too.
I haven't yet powered down for 30 mins though.
Hi ilhan,
Ok thanks for the update. It would be worth switching the router off for a full 30 minutes and then retesting as this can sometimes increase the throughput speeds.
ilhan
I have shutdown the router for 30+mins and now get a reading of 69.9 D/L and 17.8 U/L - is this in line with what I should expect?
Many thanks.
Hi ilhan
Your throughput speeds (speed tests) look good based upon your sync speed
ilhan
I've run into speed problems again, 22DL and 12UL after shutting the router down for over an hour.
There must be an issue because I've noticed a gradual decline over a few weeks.
Hi ilhan,
Sorry to hear your speed has dropped again. Your sync speed looks fine, have you noticed any improvement in speed since your last post?
