Search instead for
Fibre Connection up and down, getting worse everytime.
Sl33pingKattZ
Our Fibre Connection keeps dropping in speed and is very inconsistent in what it drops to and goes back up to, had the Talktalk router replaced with a brandnew top notch netgear router and was happy to see the best speed our connection had been, it sat perfectly stable at 20Mbps on the connection down, and 2Mbps on the up.
The last month or so though the speed has never been back to 20, it drops frequently, and everytime it drops it gets down even lower than the previous times.
Sometimes the connection goes all together but comes back after a little while, its not that often though.
Its not the router and i haven't been switching it on and off or restarting its the connection.
Help much appreciated as borderline switching provider at this point after other problems.
It's difficult to be sure without seeing the line stats for your non-TalkTalk router, perhaps you could paste them here? Also can you do a speed test for both wired & wireless connections without any other devices using the router.
Sl33pingKattZ
20170519_153233.jpgWireless speedtest
 Im currently unable to perform a wired test due to my laptop which is the only device that can reach a wired connection is broken.
These are the best I can do as of now.
I assume that this is when the speed is slow? That is low for a fibre connection, but it all depends on how far away you live from your fibre cabinet. After 300 meteres the VDSL2 signal drops away dramatically.
Based on the 17M download on the router, a 16M wireless speed test is about right.
Sl33pingKattZ
Problem i have is that it sat perfect at 20 and the wireless speed was much better. Then one day it decided to drop down to lower and lower speeds, it does go back up but only to low 18s on the throughput for the router, not 20 and almost as fast drops down to low 17s. For fibre its not great.
As I said the first thing to work out is how far away you are in metres from the fibre cabinet. If you can tell me that, I can work out the best fibre speed your router can achieve & from that I can help you make sure that you are getting the best possible constant WiFi speed.
Sl33pingKattZ
About 1235m away from the exchange
No not your exchange, your fibre cabinet:-
Sl33pingKattZ
Ah my bad, Not sure of that, actually i dont even know where it is.
Sl33pingKattZ
Think i found it. 490 metres give or take direct and indirect 800 metres
I'll take the indirect, as it will be how the cables run. 800 metres is not good, this puts the router at about 18 - 19M, so you saying the router at max achieving the 20M is about the very best possible speed, but it is very dependant on the cable quality. Personally, I think the 17M your router showed in the screenshot you sent is about right.
Whilst I also think the wireless speedtest is also about right, I can certainly help you make sure the wireless is running at its best if you want. Wireless speeds can most certainly drop for no apparent reason & I think this might be the cause of the problem.
Sl33pingKattZ
The wifi speed is consistant and naturally is lower by a percentage than the throughput. But its mostly the up and down of the throughput daily/weekly when for a while it was perfect 20.00Mbps and stuck like it for a long time. That has now turned into this which is annoying.
The WiFi speed cannot be lower than the throughput, because throughput is something totally different and is directly related to the number of wireless clients connected to the router, and the lowest WiFi mode in use.
By throughput I assume you are referring to the router's downstream line rate (the 17M in your screenshot), a wireless speedtest will always be lower than that (generally about 80% of the downstream line rate).
Sl33pingKattZ
Yeh thats what i meant. The downstream speed
So after all this, I am not sure where you can go with it as it all seems correct for your line length from the fibre cabinet. My offer still stands to help you check the quality of your WiFi signal, if you want it.
Sl33pingKattZ
Think im ok, appreciate the help and all though. Will see if a TalkTalk employee wants to have their say before i do anything else.
Goin to wait out this post and see if they reply.
Cheers for the assistant though my friend.
Sl33pingKattZ
Any TalkTalk employee available to help out as the speed has dropped even more as of today.
Sl33pingKattZ
Any TalkTalk help would be appreciated? Just wondering if I could get some help is all...
I have already passed it to them.
Hi Sl33pingKattZ,
I'm sorry for the delay. I've completed a line test which hasn't detected a fault and the current sync speed is within the predicted speed range for the line.
In regards to the intermittent connection, does your master socket have a test socket? Are you experiencing any issues with the voice service such as noise on the line?
