Fibre Speed Boost not working
5 REPLIES 5
Hi, I have recently renewed my broadband contract and added the "Fibre Speed Boost" option.  However I have seen no increase in speed and appear to still be capped at 40Mbit down and 10Mbit up. My router (Draytek Vigor) is reporting this.
Downstream            Upstream
Actual Rate40000Kbps9997Kbps
Attainable Rate56131Kbps15275Kbps
I know the line is capable of much faster as I used to have the "Fibre Speed Boost" enabled and was getting around 70Mbit downstream.  Does it take time for the Fibre Speed Boost to be applied?  I have tried powering the router off for 30 mins as suggested on other posts but no change.
Hi @hacka1979
The forum is not real-time 24/7 support, so depending on how busy they are & how many are working at any one time, this can take 24 - 48 hrs (excluding weekends & limited cover on Bank Holidays). The posts are responded to in time/date order, oldest first. So the fewer entries you make on your thread now, the sooner they will pick it up.
Hi @hacka1979,
Sorry to hear the speed hasn't changed since ordering the Fibre Speed Boost.
I have placed a manual request for this to be updated and this will take up to 24 hours to complete.
Once completed, if you could please power down your router for 30 minutes tomorrow afternoon, you should see the speed will then be correct for the boost you requested.
Amii C
Thanks Amii, will I get an email to confirm it's been done or should I just try rebooting in 24 hours ?
Hi hacka1979,
As i have placed it manually, you won't receive an email to confirm completion.
However I will monitor the order for you and let you know once completed so you can carry out the power down.
Amii C
Hi hacka1979,
The order has now completed.
Please can you power down your router for at least 30 minutes and then you will see the new speeds coming through.
Amii C
