Fibre Speed Boost
Hi Larry,
Could I just clarify, the throughput speed is exactly the same when running the speed tests using the wired PC and with all other wireless devices removed?
larrywilkie
Wizz Kid
Hi Michelle,
Yes I ran a number of speed tests, and when it was only the desktop PC connected via cable, it was very marginally quicker but nothing significant
Larry
Hi Larry
I have advised our Network Team of this testing and I will post back shortly.
Hi Larry
Our Network Team have asked if you could connect the latest router that was sent to you?
larrywilkie
Wizz Kid
Hi Debbie,
Latest router is now plugged in as requested.
I have run a couple of speed checks, but assume it will take a while to get up to speed as these came out at around 12mbps, and roughly the same for upload speed?
Larry
Hi Larry
Your line is in sync at 62.8mb. Please can you power down your router for a full 30 minutes and then run a wired speed test following this?
larrywilkie
Wizz Kid
All done but not much improvement on the download speeds.
Now just over 14mbps
Larry
Hi Larry
Were any other devices in use and connected at the time of the speed test?
larrywilkie
Wizz Kid
Hi Debbie,
I've switched Wi Fi off so that nothing is connected via that, and no other devices running currently apart from this desktop PC.
Just run another check and download speed 14.8
Larry
Hi Larry
Our Network Team would like to arrange an Openreach engineer visit.
Please can you confirm possible engineer charges and provide your availability for this visit AM and PM?
larrywilkie
Wizz Kid
Hi Debbie,
I can confirm I have checked charges and will be up to £40.
I am free all day tomorrow, Thursday 18th in the morning, all day Friday 19th, Monday 22nd in the morning, Wednesday 24th in the afternoon or Thursday 25th all day.
Hope one of these is suitable?
Shall I go back to using my WiFi Hub, as I was getting faster download speeds through that?
Larry
Hi Larry
The potential charge for the TT engineer is £40. We are now looking to arrange an Openreach engineer visit instead.
During your appointment the Openreach engineer will carry out checks to see whether you have a fault in your property or garden. If the fault is outside of your property, they will carry out the necessary work on the Openreach network and the exchange. It will appear on your bill as Engineer charge. The maximum potential charge for this visit is £65.
Hi Larry
Did you have a chance to look at my last post in regards to the engineer visit? (change from TT engineer to Openreach) Would you still like to go ahead with a visit?
larrywilkie
Wizz Kid
Hi Debbie,
Sorry, I thought I had replied!!
Will the Openreach engineer check everything that a TT Engineer would have checked as well?
Just wanted to make sure it wasn't a case of having a TT Engineer out as well if the Openreach Engineer couldn't find anything.
If the Openreach Engineer is going to check everything then yes I would still like to go ahead.
Thank you
Larry
Hi Larry
Yes the engineer can complete checks. I would advise running a speed test when the engineer is there with just one wired device so they can see the results.
larrywilkie
Wizz Kid
Ok thanks Debbie.
I'll make sure that is done.
Larry
Hi Larry
Thank you for your reply.
I've passed your availability for an engineer visit over to our Network Team and I will post back on this thread to confirm the date and time of this visit.
Hi Larry
The engineer visit has been arranged for tomorrow (19th) AM (8am - 1pm)
larrywilkie
Wizz Kid
Hi Debbie,
Thank you very much.
I'll post an update on here.
Thanks again
Larry
