Fibre Speed Boost?
10 REPLIES 10
I recently signed up for another 18 months for TalkTalk Faster Fibre, I also signed up for Fibre Speed Boost.
I can see the boost on my account under "Your flexible Broadband boosts" but my download and upload speeds haven't increased.
Is the boost actually enabled?
Hi @gavinbrattan two things worth trying.
1 Check your sync speed if it is over 39999 yoou  are half way there
2 Try a 30 minute reboot this often works by resetting the profile and taking advantage of the boost.
Thanks for the reply.
I tried a 30 minute reboot but nothing seemed to change. I guess I can't expect too much improvement given these figures?
Downstream Upstream
Actual Rate [Kbps] 32399 8359
Maximum Rate [Kbps] 43734 8359
Hi  @gavinbrattan thanks for the information. I think you do need the TT team on this as the sync details would suggest that the boost is a  waste of money.
Let's see what the guys say,they are very good!
D
All line tests are clear, but the sync speed is lower than it should be, and the profile is set low.
I can see a lot of drops.  I've a new router on the way so this can be ruled out.
Thanks for the new router, I've had it plugged in for a few days now but the speeds haven't really changed:
Upstream line rate (kbit/s):7768
Downstream line rate (kbit/s):32398
Maximum upstream rate (kbit/s):7768
Maximum downstream rate (kbit/s):43732
Is there anything else I can try?
Hi Gavin,
Are you experiencing any problems with your telephone service, any noise on the line?
How many telephone sockets do you have? Do you have anything connected to your telephone socket(s) in addition to your router?
I don't use the telephone line, but I've just done a quick check and it seems ok. There's nothing else plugged into the telephone sockets.
Guess I might as well cancel the speed boost!
Thanks,
Gav
Hi Gav,
Your connection looks stable and your router is in sync at 33.9Mbps. Is your router situated close to other electrical devices that could be causing interference? Does it connect to a multi-socket electrical extension lead shared with other device?
Hi Chris,
The router was connected via an extension, I've just plugged it into a separate mains socket.
The router is also next to a mesh network device connected by ethernet (wifi isn't enabled on the router). Could interference affect the DSL speed?
Thanks,
 Gav
Hi Gav,
Thanks for the update. Does the master socket have a test socket?
Your guide to master sockets
