Fibre Speed drop since yesterday.
13 REPLIES 13
Hello, I have noticed my fibre speed has dropped a lot since yesterday. It may have been a few each days before that as it was OK last weekend. Have been through the guides to troubleshoot the problem and nothing has  changed.
Just done another speedtest on PC and on my Mobile phone (using wireless)
Any help welcomed. I have been using fibre for over  a month now.
Have chatted to an agent online about this as well. Using the community for additional help
Hi @Dragon988 how are your wired speeds?
About the same
Hmmm can you see what your sync value is in the router Check your sync speed ?
Sync value? not sure what you mean.
H @Dragon988 the link in my last post explains it much better than I can?
Hi Dragon988
Apologies for the delay.
It appears that this fault has been raised to Openreach. Please can you post back on this thread tomorrow and we can check for further updates from Openreach.
It should be 36 to 40mbps
OK i will
Hi Dragon988
Thank you, we should hopefully have received further updates from Openreach.
All looks good today.
Hi Dragon988
Is this the speed you were receiving before you experienced this fault?
Yes, this was about the same speed i was getting before i had this problem. Though i have read somewhere i should be in between 38-40mbps. Not to worried about that as long as its close to it.
Hi Dragon988,
Ok thanks for the update and please let us know if you need any assistance 🙂
