Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Fibre available with BT but NOT TalkTalk..
sosweet1
Hi, OR have just (2 weeks ago) upgraded my cabinet, we were the last cabinet on our estate to be done, anyway went to try and order it with TalkTalk and it says its not available, but if i check with BT I can order it, any idea how long it will take for TalkTalk to update their Database?
BT may have installed or upgraded their cabinets to fibre, but it is usually a couple of months before other providers have access to provide fibre services.
All I can advise is to periodically check our website.
Check & Report l Our latest Blog l Share your Ideas l Service Status l Help with your Service l Community Stars
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
sosweet1
So my choice are either wait a few months OR just change provider - decisions decisions...
crosers
I have the same issue, openreach website says "FTTC" enabled and  links to talktalk as a provider?
