Fibre speed boost only 40mb down
3 REPLIES 3
DP50000
Got fibre speed boost for quite some time, but only getting 40mb down on a wired connection to PC.
Line 1
Downstream Upstream
Actual Rate [Kbps] 79999 19999
Maximum Rate [Kbps] 89324 19999
Noise Margin [dB] 8.50 15.20
Attenuation [dB] 15.60 0.00
Power [dBm] 12.50 6.70
Seems like I have the right profile.
Is there another issue as it seems I am being capped at exactly 40Mb?
Kind regards,
DP
OCE_Debbie
Hi DP50000
I've checked and your line is showing in sync at 79.9mb.
Please can you power down the router for a full 30 minutes and then run a speed test following this?
DP50000
Thank you.
Works like a charm now.
OCE_Debbie
