My usual download speed was in the 30's. about what I expected due to my distance from the cabinet, but recently it has started dropping.
These are the last two days figures from Thinkbroadband's speed test
25-03-2019 16:31:03 (GMT) | 5.9 Mbps | 2.6 Mbps | TalkTalk | view result |
24-03-2019 11:23:19 (GMT) | 19.7 Mbps | 3.2 Mbps | TalkTalk |
this is a serious fall off in service. What's the answer to this?
Hi A1, is that a test wired or WiFi?
Any changes in your household? New bits of kit, telephones microwaves?
Has the quality of your landline changed, any noise or crackles?
Have you been frequently restarting your router?
Good news is your post has been flagged for assistance and you should hear during tomorrow. Please check your community profile and add your landline phone number if necessary.
D
Hi A1exander
I've completed a line test which hasn't detected any faults and your line is in sync at 34.3mb.
Are you running wired or wireless speed tests?
Hi Debbie,
I run wired tests, the last two days I've got around 30 Mbps, but each time it takes the speed tester many seconds before it starts. This mirrors my experience when browsing, even when the download takes place at a reasonable speed I often have to wait long periods to get started.
This makes the overall time longer than 30 Mbps suggests.
A1ex
Hi A1exander,
Can you please run a set of pings and a set of trace routes, when the connection is slow, to www.google.co.uk and can you post the results. Can you run the tests on a device connected by Ethernet cable to your router
https://help2.talktalk.co.uk/how-do-i-perform-ping-or-traceroute
I've carried out the suggested tests, although performance seems a lot better now.
PING TEST
Pinging google.co.uk [216.58.201.35] with 32 bytes of data:
Reply from 216.58.201.35: bytes=32 time=21ms TTL=55
Ping statistics for 216.58.201.35:
Minimum = 21ms, Maximum = 21ms, Average = 21ms
TRACERT Test
Tracing route to google.co.uk [216.58.201.35]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 14 ms 13 ms 13 ms host-78-151-229-209.as13285.net [78.151.229.209]
4 13 ms 13 ms 13 ms host-78-151-229-208.as13285.net [78.151.229.208]
5 21 ms 21 ms 30 ms host-78-144-9-49.as13285.net [78.144.9.49]
6 21 ms 21 ms 21 ms host-78-144-4-33.as13285.net [78.144.4.33]
7 * * * Request timed out.
8 19 ms 20 ms 20 ms 108.170.238.120
9 21 ms 21 ms 20 ms 108.170.246.143
10 22 ms 21 ms 22 ms 216.239.58.3
11 21 ms 21 ms 21 ms 209.85.250.184
12 22 ms 22 ms 21 ms 74.125.242.97
13 21 ms 21 ms 21 ms 172.253.50.167
14 21 ms 21 ms 21 ms lhr35s04-in-f3.1e100.net [216.58.201.35]
Trace complete.
Also here's the latest speed test from Thinkbroadband
It appears my original problem may have been due to some short term issue with the line.
Thanks for running the tests, glad to hear your seeing some improvement. Please let us know if you experience any further problems
