Fibre speed
3 REPLIES 3
Router is syncing at 24.2mbps according to router settings, however every speed test wired or wireless or from different devices show a max of 17.9mbps. Any advice. Thanks.
CPW
Hi Colin
I've checked the connection stats and your line is showing in sync at 22.9mb.
It would be worth powering down your router for a full 30 minutes and then running a speed test following this.
Is your router connected at the test socket?
Rebooted router after 30 minute shut down and this seems to have sorted things. Thanks
CPW
Hi Colin
That's great, thanks for keeping us updated.
Debbie 🙂
