Good Morning,
I've got my new WiFi Hub a couple of weeks ago when I switched to TalkTalk. I noticed it's still running with the default firmware SG4K10001400t, which seems to have a bug that you can't turn the light off, could this be updated please?
Hi RF34R
Your router firmware should now be updated.
Thanks @OCE_Karl ,
I can confirm the router has been upgraded successfully.
Luckily the Software as a Service session i was connected to at the time has persistence enabled or the sudden loss of connection would have caused a good few hours worth of work to be lost. #Phew
Thanks for confirming. There will be no further disruption in service 🙂
