Fix a dropping broadband connection
1 REPLY 1
Methcohna
Our new Talk talk hub is dropping connection regularly. We had no issues with the old router. When I plugged in the old one to test it works fine. We have also had an engineer test the line and they said it's ok. It must be a fault with the new hub.
Can you send a replacement?
How do you connect wireless, wired, or a mixture? If a mixture is a wired connection better than wireless?
It is important to see what your line is actually capable of and what your current download speed is.
To help diagnose this issue, please can you log on to your router, by opening a web browser (e.g. Internet Explorer, Mozilla Firefox & Google Chrome etc) and then enter this address in the address bar:-
http://192.168.1.1
enter the credentials:-
username: admin
password:   the  Wi-Fi hub has its own unique password, which can be found at the top of the label on the rear of the router. It is the one labelled "router" or "admin" password, not the wireless one.
Then go to your ADSL or DSL summary page & paste the stats in this thread.
This can be seen via:-
Dashboard > See internet settings > Manage Advanced settings > TalkTalk Wi-Fi Hub
Click on the General tab then scroll down to the page to the xDSL section & copy & paste them into your reply.
Next can you also go to this speed checker (it is useful to have speed test figures taken at the same time as gathering the router's statistics):-
http://www.supportal-test.co.uk/
Alternatively use:-
https://myaccount.talktalk.co.uk/speed-checker/
Do this on both wireless & wired (if you have wired), but with never more than one device connected at a time.
Please can you paste the results here?
