I tried to change my router password putting in the username and password on the back of the router, but they weren't recognized as being correct.
There are two passwords.
Make sure you are using the correct one for the settings log in.
The log in username at 192.168.1.1 is admin and the password is next to that and not the same as the WiFi password
Hi Simon42,
How are you getting on, has Martin's advice helped?
