Frequent WiFi Drop outs
I have been having similar problems. It has affected my Hive heating/lighting control and my Echo Alexa. Hive tell me that WiFi drop-outs are happening all the time. I purchased a new hub from them and had the same problem as previously and they spent 90 minutes trying to get me set up. Then they established the WiFi problem
I have run a speed test and find that download speed is 31Mbps but upload speed varies from 0 to 0.1 Mbps!!
Hi @Haydn1
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
Thanks for your guidance, Keith. I've started my own thread now!!
