Frequent connection drop outs (part 2)
6 REPLIES 6
FU5ION
Wizz Kid
Old thread: https://community.talktalk.co.uk/t5/Fibre-Broadband/Frequent-connection-drop-outs/m-p/2394016/highli...
Forum decided it would be a good idea to block me from replying to my "old" thread... @KeithFrench
Anyway, I tried channel 1 but it seemed worse, so I've gone back to 6.
Here's also a ping from inside my room:
ping google.co.uk
PING google.co.uk (172.217.169.67): 56 data bytes
64 bytes from 172.217.169.67: icmp_seq=0 ttl=55 time=33.100 ms
64 bytes from 172.217.169.67: icmp_seq=1 ttl=55 time=465.110 ms
Request timeout for icmp_seq 2
64 bytes from 172.217.169.67: icmp_seq=2 ttl=55 time=1210.495 ms
64 bytes from 172.217.169.67: icmp_seq=3 ttl=55 time=207.392 ms
64 bytes from 172.217.169.67: icmp_seq=4 ttl=55 time=413.640 ms
64 bytes from 172.217.169.67: icmp_seq=5 ttl=55 time=936.543 ms
64 bytes from 172.217.169.67: icmp_seq=6 ttl=55 time=315.030 ms
64 bytes from 172.217.169.67: icmp_seq=7 ttl=55 time=712.716 ms
64 bytes from 172.217.169.67: icmp_seq=8 ttl=55 time=29.868 ms
64 bytes from 172.217.169.67: icmp_seq=9 ttl=55 time=29.511 ms
64 bytes from 172.217.169.67: icmp_seq=10 ttl=55 time=722.605 ms
64 bytes from 172.217.169.67: icmp_seq=11 ttl=55 time=544.620 ms
64 bytes from 172.217.169.67: icmp_seq=12 ttl=55 time=389.460 ms
64 bytes from 172.217.169.67: icmp_seq=13 ttl=55 time=554.922 ms
Request timeout for icmp_seq 15
Request timeout for icmp_seq 16
Request timeout for icmp_seq 17
64 bytes from 172.217.169.67: icmp_seq=17 ttl=55 time=1390.567 ms
64 bytes from 172.217.169.67: icmp_seq=18 ttl=55 time=390.362 ms
Request timeout for icmp_seq 20
Request timeout for icmp_seq 21
Request timeout for icmp_seq 22
Request timeout for icmp_seq 23
Request timeout for icmp_seq 24
Request timeout for icmp_seq 25
Request timeout for icmp_seq 26
Request timeout for icmp_seq 27
Request timeout for icmp_seq 28
Request timeout for icmp_seq 29
Request timeout for icmp_seq 30
Request timeout for icmp_seq 31
Request timeout for icmp_seq 32
64 bytes from 172.217.169.67: icmp_seq=32 ttl=55 time=1475.414 ms
64 bytes from 172.217.169.67: icmp_seq=33 ttl=55 time=1406.434 ms
64 bytes from 172.217.169.67: icmp_seq=34 ttl=55 time=811.760 ms
64 bytes from 172.217.169.67: icmp_seq=35 ttl=55 time=267.119 ms
64 bytes from 172.217.169.67: icmp_seq=36 ttl=55 time=480.923 ms
64 bytes from 172.217.169.67: icmp_seq=37 ttl=55 time=9.450 ms
64 bytes from 172.217.169.67: icmp_seq=38 ttl=55 time=127.597 ms
Request timeout for icmp_seq 40
Request timeout for icmp_seq 41
64 bytes from 172.217.169.67: icmp_seq=41 ttl=55 time=1518.540 ms
64 bytes from 172.217.169.67: icmp_seq=42 ttl=55 time=1947.868 ms
64 bytes from 172.217.169.67: icmp_seq=43 ttl=55 time=943.948 ms
64 bytes from 172.217.169.67: icmp_seq=44 ttl=55 time=78.724 ms
64 bytes from 172.217.169.67: icmp_seq=45 ttl=55 time=35.504 ms
64 bytes from 172.217.169.67: icmp_seq=46 ttl=55 time=120.806 ms
64 bytes from 172.217.169.67: icmp_seq=47 ttl=55 time=229.645 ms
64 bytes from 172.217.169.67: icmp_seq=48 ttl=55 time=9.673 ms
64 bytes from 172.217.169.67: icmp_seq=49 ttl=55 time=1107.233 ms
64 bytes from 172.217.169.67: icmp_seq=50 ttl=55 time=598.405 ms
64 bytes from 172.217.169.67: icmp_seq=51 ttl=55 time=98.612 ms
64 bytes from 172.217.169.67: icmp_seq=52 ttl=55 time=701.617 ms
64 bytes from 172.217.169.67: icmp_seq=53 ttl=55 time=23.190 ms
64 bytes from 172.217.169.67: icmp_seq=54 ttl=55 time=561.977 ms
64 bytes from 172.217.169.67: icmp_seq=55 ttl=55 time=276.252 ms
64 bytes from 172.217.169.67: icmp_seq=56 ttl=55 time=74.280 ms
64 bytes from 172.217.169.67: icmp_seq=57 ttl=55 time=405.736 ms
^C
--- google.co.uk ping statistics ---
58 packets transmitted, 40 packets received, 31.0% packet loss
round-trip min/avg/max/stddev = 9.450/541.416/1947.868/496.737 ms
The interference is seriously obvious. Pages were struggling to load and high ping times. Then as soon as I bring my laptop out of my room (closer line of sight to the router), everything instantly connects and the ping time improves to an avg of 12s!
~FU5ION~
My Multimedia Portfolio: jalproductions.co.uk
Hi FU5ION
Sorry to butt in, while your waiting for a reply from Keith, I've had a look and can see a lot of errors on the wifi.
I've dispatched a different model router to you so that we can actively collect some connection data via a new network tool we are testing here.
If you can connect this up and let us know, we can make sure the firmware is up to date and then this will start recording connection data relating to any devices you have connected.
Hi @FU5ION
When you have tried the new router that Karl is sending you, if you still have problems, please get me a fresh set of screenshots from the Wi-Fi analyser you are using.
FU5ION
Wizz Kid
Hi @OCE_Karl,
Can you tell me the exact errors you are seeing please?
If they contain private data then please PM me.
Cheers!
~FU5ION~
The errors are TX (Transmit) and RX (Receive).
So at the router wifi it shows a high number of these errors.
Currently showing :
WiFi Errors (Tx/Rx) 3458 / 679
FU5ION
Wizz Kid
@OCE_Karl New router is connected now.
Version SG4K10001400t
~FU5ION~
Hi FU5ION
I can see that the router firmware has updated to version SG4K10002600t
How have you found the connection since your last post?
