Frequent disconnects
7 REPLIES 7
Hi. For the past few weeks I have been having frequent disconnections at different times of day and night. Several times I have unplugged the router for over half an hour but it is syncing at 5.8 Mbps when before it was nearer 40 Mbps. I am using the test socket at the moment and while disconnects are less frequent, speeds are still slow.
There does appear to be noise on the line (crackling). I had a similar problem a couple of years ago with a previous supplier and the engineer traced the fault to there being water in the green cabinet in the street.
Many thanks.
Hi MacDuffer1
I've completed a line test which has detected a possible fault.
Noise on the line can affect the BB connection so we have to investigate this first.
Is the noise still present if you test with a corded handset at the test socket, with the router removed from the line?
I can then escalate this fault over to our Network Team for investigation.
Hi Debbie
I have tried with just the phone connected and there is still hiss and occasional crackle on the line.
Many thanks
Hi MacDuffer1
I've escalated this fault over to our Network Team for investigation and I will post back on this thread as soon as I receive further information.
Hi MacDuffer1
This fault has now been passed to an Openreach line engineer and we should receive further updates within the next 48hrs.
Hi Debbie
The engineer has just fixed the fault and all seems to be working well.
Many thanks for your help.
Hi MacDuffer1
That's great news, thanks for keeping us updated 🙂
