Grrr Wifi Hub disconnects
ANSWERED
Hi Mike,
Thanks for trying this and I'm sorry to hear this. This does sound like it is related to the line fault detected which has been passed to Openreach. If you don't hear from or see any engineers outside the property today or over the weekend then please can you bump your thread on Monday and we can re-check for an update on the fault for you.
bumped
looks like btopenreach did something to the line on Saturday morning between 10:30 and 11am
connection has been stable since then
however connection speed has dropped was originally 33mps now just below 28mps on your tool on other tools reporting between 18mps-25mps, upload speed between 6-7mps
I am also still seeing entries like these in the router logs which I do not understand as im still asleep at this point in time
16.12.2019 06:20:56InfoWIFI
WiFi security settings have been successfully saved
16.12.2019 06:06:42InfoWIFI
16.12.2019 04:31:24InfoWIFI
Channel: (36/40) Channel Hopping initiated/Manually initiated
And from just after I posted my last comment I have lost the ability to browse the internet, constant hmmmm can’t reach this page responses  on all my devices yet applications appear to be connected to the web and giving satisfactorily responses (online games etc which are normally the first to crash out and stop working)
router solid white light
your test tool says you are working on the issue as it’s detected a fault
Hi MikeD66
The engineer did leave notes to advise that this fault should be resolved following work completed on the line.
The line test however is detecting a voice/landline fault. Do you have a dialtone or are you experiencing any noise on the line?
Can’t tell at present as I’m down the gym for a few hours now. When I tested phone line on Saturday had dial tone and appeared ok
whats odd is online games connect and work but web browsers on all devices stopped this morning after initially working currently posting using 4g data but first posts on here today was using laptop browser
Hi MikeD66
If you could check the landline again when you get home as this is only fault being detected on the line tests.
If the line is clear and working ok then we can focus on the BB fault.
Ok back home, checked landline it has a dial tone and calls have been made on it today
checked broadband and it now appears to have totally gone, no web browsing and no connection to online games through various devices. Bb router showing solid white light and devices appear to see the router and connect to it
Hi MikeD66
Thank you for checking this.
The line is showing in sync and connected. Are any devices connected wired? Are they experiencing the same issue?
Well I just went downstairs with my laptop to connect via Ethernet to see if WiFi or line issue and bobs yer uncle the laptop wired to router could browse, sadly I walked back upstairs and all the WiFi devices were also suddenly back and working
so after a 5 hour outage I can see things again, however your live test app is still telling me you are working on my fault so it thinks there is still an issue
Hi Mike
I think this message is in regards to a fault ticket raised previously and the last update advised that Openreach resolved a local network issue.
If you do experience the same issue again could you please test straight away wired so we know if this is affecting wired and wireless.
Ok will try it’s just sometimes it goes and comes back before I get a chance to get to the router and wire laptop in 😞
with reference to my earlier posts today, why am I seeing those messages in the logs, I thought I read elsewhere on another thread the saving WiFi settings message usually indicated a router reboot which hasn’t been done in 2 days and the manually changing channel message is the router doing something automatically as I am asleep at the time that took place and would involve me logging into the router and forcing a channel change to see that message
Hi Mike
Just to confirm, what are the messages you are receiving? How's the connection been since last night?
i'm touching wood as I type this the connection appears to be stable so far today if still showing a slower speed than ive had before 27mps compared to 32-33mps
the messages I am seeing in the logs are
17.12.2019 04:31:10InfoWIFI
Channel: (40/36) Channel Hopping initiated/Manually initiated
17.12.2019 05:25:26InfoWIFI
there are at least 18 wifi security settings have been successfully saved logged today normally appearing in pairs with 2-3 seconds between them - this number is well up today usually in single figures (1 or 2 a day)
the same with the channel hopping one every day around the same time in the morning I am guessing this is automated somehow within the router  or initiated by TalkTalk as the only way I can achieve this is to log onto the router and manually force a channel swap and given im fast asleep at that time and have left the router on all its default settings including channels then I cannot understand why I am seeing the message in the logs....
Just checked the logs and the channel hopping is a regular event at 04:31 in the morning either switching from 36-40 or 40-36 or from 1-11 or 11-1 so to me this is deffo some automated tasks either within the router or fired out over the network by TalkTalk which in my humble opinion is slightly flawed as channels have been changed on the router in the past on the advise of TalkTalk tech teams to rule out wifi interference and this automated task undoes those changes every morning which is just plain daft
Hi Mike,
Thanks for the update and please let us know how the stability compares over the next 24hrs. Our performance monitoring tool will only change channels when interference is detected.  It will learn about each device that is connected over time. Is this affecting the performance of the connection?
And there she blows @ 13:30 I lose my internet connection
wired laptop into router to rule out WiFi issue and still no connection
landline has dial tone
so I guess we rule out WiFi interference and it’s a line/router/network issue
And after 10 mins the internet returns
And what I have also just done is move the 5ghz band to channel 100 well out of the channel range my SkyQ and SkyQ mini boxes use (36) - one would have thought being on 40 would have been space enough, what's the wager tomorrow morning its changed back to 40 🙂
I must admit I still don't get why it switches channels at the same time every morning 04:31am
As an aside most of my devices use the 2.4ghz band on channel 6 before we jump to the its the SkyQ boxes causing wifi interference on channel 40 conclusion
15:50 I lose internet yet again on all devices
WiFi hub showing 6 devices connected
