HG633 VERY unreliable internet speeds
9 REPLIES 9
I have been experiencing recently very poor internet speeds.
Talktalk promises me anywhere between 30-40mbs (download). However in recent times I have tested my internet speeds and I have got no where near this.
1) 15mb
2) 20mb
3) 30mb
These numbers fluctuate every time I test the speeds.
I have used the following websites to test the internet speeds.
https://www.talktalk.co.uk/speedcheck/
https://www.speedtest.net
I have tested this connection with the computer that is right next to the router.
These tests have been on the same computer. The same web browser.
any thoughts and suggestions would be amazing please.
Currently the "Internet" & "Wireless" lights on the router is flashing green. Flashing together, both lights at the same time. Both are blinking on and off together. Not sure if this helps?
What is the router's downstream line rate? Have the speed tests been carried out over a wireless or wired (Ethernet) connection to the router?
These tests have been carried out over a wireless connection.
How will I be able to find the routers downstream line rate so I can help you please?
Log into the router & go to:-
Maintain > System Information > Broadband Information
Here is the information
Connection status: Showtime
Upstream line rate (kbit/s): 9094
Downstream line rate (kbit/s): 39806
Maximum upstream rate (kbit/s): 9094
Maximum downstream rate (kbit/s): 53352
Your router is delivering what TalkTalk have promised, right at the top end of just under 40M.
The HG633 is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
Having said that, there is another approach which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. This is available on the HG633 (V2.00), to enable it, first set both SSIDs to the exact same name. Then go to:-
Home Network > Wireless Settings > Enable Wireless Network Frequency Bands
Then put a tick against Enable Band steering.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Thanks for the response,
I have the bands already correctly named.
I would be interested to see this guide that you mention please.
How would you send this to me please?
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button on the post editor's toolbar as large images. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
I have just sent you a PM with the screen shots
I see that you have a Netgear WiFi extender, don't you? This is using the same channel 1 as the router & is dwarfing the router's WiFi signal. Depending on the type of extender this is, it could obliterate all of your WiFi like this. Try moving the router from channel 1 to channel 6 & then get me a fresh set of screenshots.
