HG633 update
5 REPLIES 5
Hi I have just acquired HG 633 router and wish to use it as  WiFi extender  using a HG635 as the main router,but before I even try to set it up I need to update the 633 to latest version can you explain what needs to be done for me to do this please
The only way to get a firmware update for a TT router is to have it connected to your incoming line.
For all that follows, I am assuming the 633 was supplied by TT.
Replace you 635 with the 633 and perform a factory reset.
Check the firmware version.
I am not sure as to the latest firmware version, but the "search" function on here will no doubt find it !
Once connected the firmware should update automatically, you cannot force it to happen.
If it fails to do so, come back here and request that an OCE schedules an update.
Martin
Thanks for  input, although TT did not directly supply me with the 633 it is one of theirs, I shall do as you say and await the outcome
Latest firmware for the HG633 is V2.00t
If not updated, connect the router directly and post back and we can push the firmware to you.
Thanks Karl,booted it up this morning and it's showing Version 2.00t so it is up to date,all I need now is a Dummies guide to use it as a WiFi extender,I have looked it up and it starts to go over my  head two lines in lol
Excellent, thanks for letting me know.
