Hi Wellandg
Did this only happen after the firmware was updated?
Will the devices re connect on their own or do you need to reboot the router/device?
Hi Wellandg
Could you try factory resetting the router using the pin hole reset for ten seconds and then retesting to see if you still experience this issue following this?
Hi Wellandg
Apologies for this.
Our Products Team have asked which devices are now not re connecting? Has the software been updated on all these devices? (any software updates waiting)
Hi Wellandg
I can send a replacement router for testing, would you like me to arrange this?
Hi Wellandg
Great News, thanks for the update 🙂
