Search instead for
HG635 Wifi dropping out on 2.4ghz
msh101
I'm having problems with the 2.4ghz connection on wifi, the 5ghz is fine only 2.4ghz drops out and you have to reboot the router to regain connection, I have run the Acrylic app to show all wifi conections (we live in a hamelt of 6 houses and no other signal is detected). Any ideas ?
regards
Mark
Please can you send me screenshots from Acrylic with your 2.4Ghz network highlighted? The views I need to see are:-
  1. Signal strength
  2. 2.4GHx channels
Then I should be able to help you.
msh101
Hi Keith, here are the screen shots,
Hi have tried different channels etc, the wifi on 2.4ghz can be ok for a while and then becomes intermittant, last night it dropped for several hours before comming back, (the 2.4ghz was not transmitting and not shown when cheking with Acrylic).
regards
Mark
msh101
What is happening to your WiFi signal in the last graph? Personally, I would use channel 11 & set the 802.11 bandwidth or channel bandwidth to 20MHz only. Using two channels would seem to be correct, but it is impossible to know with those few screenshots exactly what happens at other times of the day.
Where roughly is the router situated in your property & where was the PC running Acrylic in relation to the router? Do you live in a new build property with loads of insulation between the internal walls? Is the router or your PC situated near any metal objects, loudspeakers TVs cordless phone base stations etc?
msh101
Hi the last graph shows the 2.4ghz signal droping out, the router is at the front of the property and i'm about 8 feet way on the other side of a stud partioned wall, the house is 120 years old, this problem has just started (last couple of weeks), the problem is the router has developed a fault, (I was a telecomunications engineer for the MOD and now an IT architect for a multinational IT company).
Aprechiate any help,
Mark
Maybe it is the router then. I will escalate this now for you to one of TalkTalk's OCEs to pick your thread up and they will investigate it for you.
The forum is not real time 24/7 support, so depending on how busy they are & how many are working at any one time, this can take 24 - 48 hrs (excluding weekends & Bank Holidays). Alternatively, you can call the call centre or use on-line chat. The posts are responded to in time/date order, oldest first. So the fewer entries you make on your thread now, the sooner they will pick it up.
Otherwise, TT will not be able to tie up your forum username to your broadband account. Only you & TalkTalk have visibility of your details.
msh101
Thank you Keith, much apprechiated.
Hi msh101
I've updated the firmware for the router, see if this helps with the performance.
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
msh101
Thank you Karl, I'll see how it goes.
Mark
No Problem 🙂
msh101
Hi Karl, unfortunatly the 2.4ghz wifi has started dropping out again, no problem with 5ghz.
If you want to get me some fresh screenshots, I'll take another look.
Hi msh101
Would you like to try a replacement router ?
msh101
Hi Karl, yes I would appreciate a router to try.
Mark
A new router is on the way for testing.
This should arrive in the next 24-48 working hours.
msh101
Thank you Karl Thumbs up
No Problem 🙂
msh101
Hi Karl,
Just a quick note to let you know all is now well, there have been no dropouts with the new router.
Mark
Hi Mark
That's great, thanks for keeping us updated :-)
