HG635 port warning. Will update help?
5 REPLIES 5
62ARG62
My HG635 is showing port warnings when scanned with Bullguard network scanner.
Would updating the firmware from v1.06t to v1.10t help?
Here is what I am seeing via scan.
Have you set up any port forwarding for these ports?
62ARG62
No, never touched it. This is the first time i've seen this on any router I have had.
Try giving the router a factory reset & see what it is like then.
62ARG62
No. Exactly the same. Showing port 9091 open.
It is the applications on a device that actually open ports, I would think therefore this is something that is opening the port via uPnP, which can be disabled on the router. One such thing (from a quick Google search) that uses 9091 is a game called "Championship Manager 4":-
https://www.speedguide.net/port.php?port=9091
I would suggest you start scanning your devices to see which has this port open.
