No internet! No landline to check service. Need help! Need internet for work flashing amber. Then flashes amber and green.
Hi Joanna,
We'll then look into this further. Please do not post this information on this thread Once you've updated your profile please post in your topic to confirm it's updated.
Hi Joanna1989
I've completed a line test which hasn't detected any faults and your line is showing in sync and connected.
Are you still experiencing this fault?
