High latency Wifi and Ethernet
19 REPLIES 19
alexauron
I recently joined TalkTalk transfered from a previous ISP in the same home.
I'm experimenting unusual high latency while playing games online.
Via Wifi 5ghz my average ms is between 35-60ms.
Via Ethernet my average ms is 19ms fixed.
With my previous ISP I could reach 10ms via Wifi, didn't even need an ethernet connection because the ms was good enough.
Any clue how could I solve this issue?
Hi alexauron,
  • Name
  • Telephone number
  • Alternative contact number
alexauron
Hi Michelle,
Thanks for your post, I updated my profile.
Hi alexauron
The connection stats look good and no issues have been detected on the line test.
@KeithFrench provides really good advice on improving wireless performance. Could you help please Keith?
Hi @OCE_Debbie  @alexauron
Is the problem just on the wireless connections now, as the thread title says it affects Ethernet as well?
alexauron
I tried WiFi and couldn't manage to play anything. So I tried via ethernet and still no luck.
Just want to highlight that my previous ISP had better latency via WiFi than TalkTalk via ethernet...
Hi @OCE_Debbie
Back to you then as the OP says it does affect wireless & Ethernet connections.
Hi alexauron,
Thanks @KeithFrench 🙂
Could you run a wired ping and trace route and post the results into the thread.
Run a Ping or Traceroute
alexauron
I won't have access to my computer until Sunday. I will post the commands output on that day.
Hi alexauron,
Ok thanks for the update 🙂
alexauron
Hi, sorry for the delay.
These results are using LAN cable:
Tracert
Tracing route to google.co.uk [216.58.204.35]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  ttrouter [192.168.1.1]
  2     *        *        *     Request timed out.
  3     4 ms     4 ms     4 ms  host-78-151-234-49.as13285.net [78.151.234.49]
  4     5 ms     4 ms     4 ms  host-78-151-234-52.as13285.net [78.151.234.52]
  5     6 ms     6 ms     6 ms  host-78-144-12-57.as13285.net [78.144.12.57]
  6   109 ms    51 ms     7 ms  host-78-144-4-35.as13285.net [78.144.4.35]
  7     7 ms     9 ms     7 ms  108.170.246.161
  8     6 ms     6 ms     8 ms  108.170.238.119
  9     6 ms     6 ms     6 ms  lhr25s12-in-f3.1e100.net [216.58.204.35]
Trace complete.
Ping
Pinging google.co.uk [216.58.204.35] with 32 bytes of data:
Reply from 216.58.204.35: bytes=32 time=6ms TTL=54
These results are from Wifi 5g:
Tracert
  1     2 ms     3 ms     2 ms  ttrouter [192.168.1.1]
  3     9 ms     6 ms     5 ms  host-78-151-234-49.as13285.net [78.151.234.49]
  4     6 ms     6 ms     7 ms  host-78-151-234-52.as13285.net [78.151.234.52]
  5    17 ms     9 ms     7 ms  host-78-144-12-57.as13285.net [78.144.12.57]
  6     8 ms     9 ms     8 ms  host-78-144-4-35.as13285.net [78.144.4.35]
  7    10 ms     8 ms     9 ms  108.170.246.161
  8     8 ms     9 ms     8 ms  108.170.238.119
  9     8 ms     9 ms     8 ms  lhr25s12-in-f35.1e100.net [216.58.204.35]
Trace complete.
Ping
Reply from 216.58.204.35: bytes=32 time=8ms TTL=54
Reply from 216.58.204.35: bytes=32 time=33ms TTL=54
Thanks!
Hi alexauron,
Thanks for running the tests
Could you explain what you mean when you said "I tried WiFi and couldn't manage to play anything. So I tried via ethernet and still no luck." - What exactly happens when you try to play your games?
alexauron
Sure,
Eventually, I have lag. I cannot even use discord for chat with my mates, which is breaking up my voice even when not playing. I cannot play because the experience is unsatisfactory.
Lan cable helped a bit, but still not as good as I had with my previous ISP over WiFi.
Thanks for the information. Can you switch your router off and leave it off for at least 30 minutes, then switch back on and retest, please let us know how you get on
alexauron
After 12 hours disconnection:
With Lan cable
  3     6 ms     4 ms     5 ms  host-78-151-234-49.as13285.net [78.151.234.49]
  4     6 ms     4 ms     6 ms  host-78-151-234-48.as13285.net [78.151.234.48]
  5     5 ms     6 ms     6 ms  host-78-144-12-5.as13285.net [78.144.12.5]
  6     6 ms     6 ms     6 ms  74.125.51.110
  7     *        *        *     Request timed out.
  8     8 ms     7 ms     7 ms  216.239.57.120
  9     6 ms     6 ms     5 ms  108.170.238.119
 10     6 ms     6 ms     6 ms  lhr25s12-in-f3.1e100.net [216.58.204.35]
Trace complete.
Reply from 216.58.204.35: bytes=32 time=15ms TTL=54
Ping statistics for 216.58.204.35:
    Minimum = 6ms, Maximum = 15ms, Average = 8ms
With WiFi 5g:
  1     2 ms     5 ms     2 ms  ttrouter [192.168.1.1]
  3     8 ms     7 ms     6 ms  host-78-151-234-49.as13285.net [78.151.234.49]
  4     6 ms     8 ms     6 ms  host-78-151-234-48.as13285.net [78.151.234.48]
  5     8 ms     7 ms     8 ms  host-78-144-12-5.as13285.net [78.144.12.5]
  6    10 ms     8 ms     8 ms  74.125.51.110
  8    25 ms    29 ms    35 ms  216.239.57.120
  9     9 ms     8 ms     8 ms  108.170.238.119
 10     8 ms     7 ms     8 ms  lhr25s12-in-f3.1e100.net [216.58.204.35]
Trace complete.
Reply from 216.58.204.35: bytes=32 time=7ms TTL=54
Reply from 216.58.204.35: bytes=32 time=9ms TTL=54
    Minimum = 7ms, Maximum = 9ms, Average = 7ms
Hi alexauron,
Thanks for trying that, the test results look OK. has there been any improvement in gaming performance?
alexauron
I will give a try this evening.
Hi alexauron,
How are you getting on?
alexauron
I gave a try and seems to be much better now,but  didn't  opendiscord tho.
I will keep testing this month to check if the issue is finally gone.
Thanks for everything!
Hi alexauron,
