How do I upgrade from FasterFibre to SuperfastFibre?
6 REPLIES 6
JamesRoz
A friend of mine says that he pays for speed boost but I can't find any way to do that from my TalkTalk account page.
Can you please help me to locate/buy the option?
Thanks, James
OCE_Debbie
Hi James
If you log into My Account, does this show under offers and upgrades (at the top of the page)
  • Name
  • Telephone number
  • Alternative contact number
martswain
The boost is not available on all lines because speed is dependent on the distance to the cabinet from your home, every line is different.
If TT cannot guarantee a minimum speed well above 40 Mbps they will not, quite rightly, sell you a boost that cannot work.
Martin
JamesRoz
Hi Debbie @OCE_Debbie
Updated as requested.
Thanks, James
OCE_Debbie
Hi James
Thank you. I'm just sending you a Private Message to confirm some details so I can check the predicted speed range for your line.
OCE_Debbie
Hi James
Thanks for the Private Message.
I have checked and the reason why the speed boost does not show available to add is because of the predicted speeds for your line.
The range is showing between 37 and 36mb, with a minimum guaranteed speed of 35mb.
JamesRoz
Thanks for investigating Debbie.
That's a shame about possible speeds because I could really do with an increase but understand the technical limitations of the network.
Thanks again,
James
