Hub Device info
1 REPLY 1
Pash02
Super Duper Contributor
Everything set up changed passwords and channels but because i logged my phone in to the network  and then changed the network name i had to log in again on my phone to wifi
What channels do you use or should i just leave it on auto?
Now i have my phone listed as two devices and cant find a way of removing one of them
The Ip address is different for each one also
Help Please
OCE_Michelle
Hi Pash02,
Have you tried factory resetting the router and then resetting this up again? If you're not experiencing any issues with the wireless connection then I'd recommend leaving this on auto.
