IPv6 on HG633
3 REPLIES 3
I have a HG633 router, and I am wondering whether I should enable the IPv6 DHCP server on the router or not, what is the best configuration (autoconfigure subnet or autoconfigure DNS)? And also whether this applies to WAN, LAN or both?
Thanks,
Rv
Hi rvboutin,
We generally recommend leaving these settings set to default
Hi Chris,
Thanks… but because I changed setting a long time ago, I do not remember if I changes this setting or not from default. What is the default setting? on or off?
Also, does IPv6 works only on LAN connection (Ethernet) or also the WiFi?
Thanks,
Rv
Hi rvboutin,
To be honest I don't know what the default setting is, are you experiencing any particular problem with your service?
If you're concerned about the settings then you could reset your router to factory default
