Improving my connection for gaming
As you said the DMZ "Should" resolve any port blocking issues and allow it to run freely outside the network.
Run a ping test - https://www.netmeter.co.uk/ping-test/ - going by what your getting I would say it should be in the acceptable range.
Also follow Michelles link when your having problems so TT can follow this on for you.
I would try,
Full factory reset on the router by pressing and holding the reset button for 1/2 mins, then looking for a f/w update TT.
"Any unofficial fw may void the warranty and TT may charge you"
2. Try another brand of router (Most routers are able to self setup to TT network).
I remember having a very old D-Link router (about 10 years ago) and I was on ADSL and I had an similar issue from what I can remember.
Thanks for running a health check on my line Michelle.
When I setup my laptop ill run a wired speedtest and traceroute and post the results.
Growing in Power
Thanks for all your help and suggestions Liquid. I have tried resetting the router, I believe the router automatically searches for the latest official F/w upon reset. I also turned off my router for over 30mins so that my router would request a new external IP address.
I was considering a new router, but I have no idea how to sync it to TalkTalk. Would you happen to know any setup guide links for using a 'self bought' router?
Growing in Power
@FireHe I would forget about routers at the moment and concentrate on providing OCE Michelle with the information she requested. If there are any server issues then the router is immaterial. Plus as has already been observed your basic sync and throughput performance is just fine.
Hi FireHe
This help page provides some further information Set up a non-TalkTalk router
Thanks Debbie for that link.  👍
Growing in Power
Hi Michelle,
Here are my Tracerroute results:
Tracing route to google.co.uk [172.217.169.67]
over a maximum of 30 hops:
1 18 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 4 ms 4 ms 4 ms ae50-ner002.thw.as13285.net [78.144.1.3]
4 4 ms 4 ms 4 ms ae50-scr102.thw.as13285.net [78.144.1.2]
5 4 ms 4 ms 4 ms 74.125.51.110
6 5 ms 5 ms 5 ms 216.239.40.81
7 6 ms 5 ms 6 ms 172.253.66.99
8 5 ms 5 ms 5 ms lhr48s09-in-f3.1e100.net [172.217.169.67]
Trace complete.
Ping results:
Pinging google.co.uk [172.217.169.67] with 32 bytes of data:
Reply from 172.217.169.67: bytes=32 time=5ms TTL=55
Ping statistics for 172.217.169.67:
Minimum = 5ms, Maximum = 5ms, Average = 5ms
Growing in Power
hi Michelle,
Speedtest results:
Ping: 4ms
Download speed: 55mbps
Upload speed:18mbps
I hope the information provided is helpful. Looking forward to reading your analysis of my results.
Growing in Power
All looks good there. Have you tried pinging your game server?
Hi FireHe,
Thank you. The first hop shows high pings to the router. Did you run the test wired or wireless? Are you usually connected to the games wired or wireless?
Hi michelle,
All my tests were with a wired connection to my laptop.
Would you like me to repeat the tests? I will post a new set of results just in case you need them.
Growing in Power
Hi FireHe,
Ok thanks for confirming. Was the test run with just the one device connected wired directly to the router? Did you also run the test when you experienced the latency?
Hi Michelle,
I always play using a wired ethernet. While playing, my ping to the game server is 6-8ms for Apex legends. I have tried playing using the wireless 2.4 Ghz wif-fi and the ping is slightly higher at 13 ms with slightly reduced upload and download speeds. I have tried using other ethernet cables but there was no difference with its wired connection speeds/ping.
Growing in Power
I ran the test with another device connected wired to a wifi extender/powerline adapter. I will run another test with this connection disconnected.
I feel I should add that, I have tested/played with all other devices wired and wireless, disconnected from the network. I connected my Ps4 with a wired ethernet, disconnected all other devices and also turned off the broadcast of 2.4 and 5 Ghz wi-fi from my router. This did not change the poor quality of the broadband while playing.
Growing in Power
Hi FireHe,
Ok thanks for confirming this. Do you have a different router that you can test with to rule this out?
I do not have another router unfortunately. 😞
Growing in Power
Hi FireHe,
Ok, would you like us to send a replacement router for testing purposes to rule this out?
Results for new tests with no other device connected via wired or wireless.
Traceroute test:
Tracing route to google.co.uk [216.239.38.117]
  1     8 ms    <1 ms    <1 ms  192.168.1.1
  4     4 ms     4 ms     5 ms  ae50-scr102.thw.as13285.net [78.144.1.2]
  7     6 ms     5 ms     5 ms  64.233.175.91
  8     5 ms     5 ms     5 ms  216.239.38.117
Trace complete.
Ping test:
Growing in Power
Will this router you possibly send to me be a new router that is able to act as a replacement for my current router, or is it just a testing router that is not suitable for day-to-day use?
Growing in Power
