I am looking for service support for intermittent fibre broadband service.
I joined Talk Talk in January after moving to my new address.
I used a secondary telephone socket for a week, which is in a preferred location but is damaged - the connection was poor and I lost connectivity frequently.
A BT engineer did some work to the master telephone socket and moved our router there. This improved matters, but the service is still unreliable and cuts out several times a day.
I believe the line need repairing, and the master socket, which is very old, needs checking/replacing.
How do I go about getting support from a Talk Talk/BT engineer?
Thank you.
Hi Kathryncecilia
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
My number is correct and up to date.
Please can you get on with processing my request for help now?
Kathryn
Hi Kathryncecilia,
We need your TalkTalk landline number to be able to look into this, the only numbers you have included on your profile are mobile numbers.
Please update your community profile with your TalkTalk landline number and update us via this post one done.
Mark
Hi Kathryncecilia
Apologies for the delay.
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Can I just check which router you are using? (make and model) I'm unable to connect to your router to check this, apologies for this.
Hi Kathryn,
Thanks for confirming and I'm sorry for the delay. I've re-checked the connection stats and the connection now looks stable for almost 4 days. How have you found the stability since your last post?
Hi Kathryn,
Thanks for confirming and I'll take another look now. I've re-run the line test which is still clear, however I can see a couple of re-connections on the line. Does your master socket have a test socket? If it does then would it be possible to connect the router at the test socket to see how the stability compares?
Is the voice service also ok with no noise on the line?
