Intermmitent Wi-Fi on some devices
The Simpsons
Chat Champion
Yes I still get the same message.
OCE_Debbie
Hi The Simpsons
Do you receive this message if you test in a different browser?
The Simpsons
Chat Champion
I am using Chrome and tried using internet explorer but could not get on...
Tried using Chrome and it says wrong password and it is not wrong...
OCE_Michelle
Hi The Simpsons,
I'm sorry to hear this. I've run a test on the line which has detected a potential voice fault. Just to confirm, are you experiencing any issues with the voice service such as noise on the line or no dial tone?
The Simpsons
Chat Champion
I don't know, we hardly ever use land line.
I am sorry if I am a bit inconsistent, I have just lost my mum a couple of days ago.
OCE_Michelle
Hi The Simpsons,
My condolences, I'm really sorry to hear this.
Do you have a phone connected? Would it be possible to check this to see if you have a dial tone or any noise on the line when it's convenient.
The Simpsons
Chat Champion
The land line has no noises. Internet is ok at the moment.
The Simpsons
Chat Champion
I am still having terrible problems with our internet I am afraid!
I have taken screen shots if that helps anyone to help?
First one was yesterday, then I couldn't get back on so gave up. The other two are now.
Thank you.
OCE_Michelle
Hi The Simpsons,
I'm sorry to hear this. One of the line tests has detected a potential fault. Just to confirm, is the voice service still ok at the moment? Is the connection also unstable?
Does your master socket have a test socket?
The Simpsons
Chat Champion
The telephone appears to be ok.
Yes there is a test socket.
The Simpsons
Chat Champion
Thank you.
OCE_Debbie
Hi The Simpsons
Apologies for the delay.
Is your router currently connected at the test socket?
The Simpsons
Chat Champion
that's ok.
It is not connected to test socket at the moment. I will do it shortly.
Internet appears to be running ok at the moment.
The Simpsons
Chat Champion
I connected router via a microfilter to test socket and I had no internet at all?
OCE_Debbie
Hi The Simpsons
Apologies for this.
Do you have a different microfilter that you can test with?
The Simpsons
Chat Champion
I did try 2 different ones. I will see if I can find another.
The Simpsons
Chat Champion
No internet using test socket I have tried 4 microfilters now...
OCE_Debbie
Hi The Simpsons
Does it connect ok if you re connect the face plate?
The Simpsons
Chat Champion
Yes?
OCE_Debbie
Hi The Simpsons
I will run another line test with all equipment removed from the line.
Would it be possible to remove everything including the face plate for 30 minutes so I can complete this line test?
